03-22-2023 09:03 AM
If you run into this error while starting your web service, first take a look here:
If that solution does not work, or does not apply to your situation, then it could be that LV is offended by one or more terminal connections on a VI connector pane. I've found that this can occur if you rename the controls or indicators that are already connected to terminals. Try un-connecting and then re-connecting the terminals.
This is with LV2019SP1. Not sure if it applies to other versions.
03-22-2023 09:15 AM
Also try removing whitespaces and certainly special characters from the names of controls connected to terminals. LV seems quite finicky here.
