08-27-2016 07:29 AM
Hello, I have this:
The idea of mean filtering is simply to replace each value in a signal with the mean (average) value of its neighbors. A mean filter is widely used for noise reduction.
Start by adding some random noise to a signal (use the file echo_1.wav or any other speech data file). Then, use mean filtering to reduce the introduced noise. More specifically, take the following steps:
08-30-2016 08:06 AM
Hi master 45,
What have you done so far? Any specific question about your application?
