05-17-2011 12:44 PM
Do you have a LIFA success story? Share it here!
06-30-2011 03:41 PM
I just wrote a little program that uses an Arduino, Hall effect sensor, magnet, 5.6kOhm resistor, 10nF capacitor, a LED and a couple wires to read the amount of teeth of a steel gear that rotate by the sensor. The program is simply a digital read and count, but with the Hall effect sensor and gear it acts like a single line relative encoder and only and cost ~$45 in hardware. It also lights the LED describing the state of the Hall Effect sensor. Good times.
07-01-2011 12:07 PM
jdskier1,
That sounds awesome. Can you post some picstures or a video? I would love to see it in action.
Sam K
LIFA Developer
12-26-2011 03:07 PM
I've used LIFA to develop a topside GUI for my homebuilt ROV. Spent a year trying to get VB6 to do what it took me a week to do with LIFA.
Great toolkit guys!
01-27-2012 11:38 PM
I'm using LIFA for my mechanical engineering senior capstone project. I'm using the Arduino Uno+Labview along with some sensors and LEDs to increase efficiency on a manufacturing process. Having Labview is great because it makes my job way easier. Thanks for making this!
05-23-2012 03:49 AM
I intergrate LIFA to my ongoing project. It's a project to control a electric bike which consists a BLDC motor for the wheel.
I use OSC (open sound control) to control the speed of the bike from my iphone.
The wheel is from amped bike
http://ampedbikes.com/kits.html
Labview recieves speed command from the iphone than send it to the arduino. Based on the required speed, the arduino control the BLDC by a motor driver shield.
For OSC i use the framework from here:
https://decibel.ni.com/content/docs/DOC-12289
With some minor change, i have this front end:
And here is the back end
It works great!
ps: I'm new to labview and still learning. If you work with labview and OSC before please contact me, i have some question that may be you can help.
05-23-2012 07:18 AM
I developed what we called Production Performance Monitor...which basically is a GUI to indicate, instant ciclye time, avg, cycle time, quality defects counter, it graphs the pieces per minute produced on the line..plus it saves it to a TXT file for analisys on excell..
the arduino is conected to a signal on the plc that makes a pulse every unit pass through the machine at the end of the line..it also has buttons to clear indicators and reset quaility defects counter..
05-29-2012 03:26 PM
At Iowa State University, we successfully used Arduino Mega 2560 with a customized version of LIFA to compete in NASA's Lunabotics Mining competition (May 2012).
10-13-2013 10:32 AM
Our company owns a quite old concrete batch plant, which had full manual control requiring an operator to control 14+ switched and observe 3 mechanical scales. I was successful to upgrade this plant to an automated unit requiring minimal operator input using custom made Arduino Uno compatible board and LIFA. Wiring is still messy which I shall take care in the near future after all testing is done.
Control Unit for the plant
The VI
The plant.
