This is a bit nitpicky, but I'm submitting it anyway because it is probably very easy to implement, has no drawbacks I can think of, and should have no implications of feature collision.
It would be very nice if there were some kind subtle indicator on the (higher level) block diagram telling you that the subVI's BD will not be visible for learning, modification, or probing. It's not a huge deal to just hit escape and then control+w to go back, but I've been doing this hundreds of times recently, having been inspired to dig through much of vi.lib after reading Darren's weekly Graphical Morsels column.
Hmmm, actually now that I'm putting the graphic together, it's not quite as trivial a choice as I first thought ... how to indicate this without interfering with the wire terminals, not adding clutter somewhere else.
The lower right hand corner seems to be the least busy place of most VI's. The graphic attached would be better if I took the effort to make the key graphic have a transparent background.
Maybe the little key icon should only show up when the user is mousing over the subVI node.
-Ben
PS Just in case you were wondering, I did not make it a resolution to be as petty as possible in 2011. Pure coincidence on timing.
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
