From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
LabVIEW Embedded
Labview Embedded for ARM - Convert hexidecimal with preceeding backslash to ASCII
- LV 2010 with Embedded for ARM module
- MCB2300
- COM1 port
I am trying to read in a serial string on this port from a serial device. I am (for whatever reason) reading in hexidecimal characters. I can either read in one byte at a time or all bytes at port.
My coming string either looks like this:
\D5\8B\D6\EC\AB\D6\EC\FB\F6\FB\F6\EBV\D6\EC\EB (if I read in all at once)
or
\DB
\8B
... (if I read in one byte per iteration)
Either way I want to convert this to ASCII characters but I can't get the '\' off the front of the string. I have tried two ways and neither works. The outputs are just blank. Any suggestions?
(6,138 Views)
Hi tir38,
Your logic inside the case structure worked for me. However, for your program, I suggest running your program in Highlighted Execution to check if the case structure hangs while waiting for the boolean input. In addition, I see that you have added the substring indicator, does that indicator show the cleaned-up HEX string correctly before converting it to a decimal?
Aldo A
Applications Engineer
(6,126 Views)
Accepted by topic author tir38
suprisingly, when I change the 1 to a 0 (i.e. remove nothing) it works.
(6,122 Views)
