07-13-2011 05:46 PM
Hello there, I am trying to compile a "stm32f10x" project using old generic template project found on the forums (for example, here) and I have gotten around some errors.
however I am experiencing an error when compiling which says:
C:\Program Files\National Instruments\LabVIEW 2010\CCodeGen\include\os\rtx\LVDefs_plat.h(98): error: #256: invalid redeclaration of type name "int8" (declared at line 157 of "C:\Program Files\National Instruments\LabVIEW 2010\CCodeGen\analysis\development\include\fundtypes.h")
Target not created
Status: Build failed.
I have tried commenting out the lines which declares the int8 variable, however by commenting one out it gives more errors (as the type is used within the file)
I am using
-Windows 7
-National Instruments LabView 2010
-Keil uVision 4.14
-J-tag/J-link device
-STM32F103RB chip
Any help would be appreciated. thanks
07-14-2011 02:59 PM - edited 07-14-2011 02:59 PM
Hi PongoBeer,
There was a thread a while back that discussed this issue. Have you seen this and tried the troubleshooting steps that were listed? Also, can you specify which file you commented out "int8" in?
07-15-2011 09:21 PM
hey there, i did try some of the things mentioned in the thread, however it was still not working
and I have tried commenting the declaration in both files, but each gave erros, however just now i have removed "stm32f10x_tim1" from the targetconfig file and the program seems to not come up with that error. however a new error has appeared that says:
[2:18:33 PM] Status: Error
linking...
.\Obj\LabVIEW.axf: Error: L6406E: No space in execution regions with .ANY selector matching stm32f10x.o(HEAP).
.\Obj\LabVIEW.axf: Error: L6407E: Sections of aggregate size 0x8000 bytes could not fit into .ANY selector(s).
Target not created
08-01-2011 08:20 AM
Hi Pongo,
Were you able to resolve this issue or are you still stuck? If you were able to figure out, what did you do?
Have a great day,
08-01-2011 05:48 PM
hey there, i am still stuck on this problem and haven't touched Labview at all ever since
11-08-2012 08:25 AM
I have got the exact build error, has anyone got a solution?
