LabVIEW Embedded
How to count the external pulses using the ARM (LM3S8962) Evaluation Board
       My target is to count the external pulses example( encoder) which is given as the input for the ARM evaluation Board( LM3S8962)... I dont know how to configure the counter mode in the PWM of LM3S8962... I am New to labview ARM and i dont know whether to use the timer VI or Interrrupts or PWM VI ? Its confusing a lot... Can any one guide me how to count the pulses which are given externally to board?
Waiting for a reply....
(5,858 Views)
Bonjour,
Avez-vous trouvé une solution ? Je suis dans le même cas que vous. Merci
Eric
Have you found a solution? I am in the same situation as you. thank you
Eric
(5,726 Views)
