LabVIEW APIs Discussions
Small bug with undo on string constant
Hi All
I have find a small bug with undo function on string constant.
I try to modify string constant with scripting aned it's ok.
But when i do one Undo to go back to the original string constant value, the square is modify but the text is not update.
Try this exempl:
1)Open Test string.vi diagram, and see free string constant.
2)Run modify string.vi.
3)Go back to Test string.vi diagram
4)The string constant are modify correctly
5)Undo
6) See the bug.  The square is modify, but the text is always here.
Eric
(3,997 Views)
I can replicate this as well.
It look like the undo transaction is not working on string constant that are modified via scripting.
PJM
vipm.io | jki.net
(2,752 Views)
