LabVIEW APIs Discussions
ANV Database Toolkit
Dear LabVIEW Community,
let me present our new ANV Database Toolkit, which has been recently released at vipm.io.
Short introduction to the toolkit is posted by this link, and it also describes steps which should be done in order to use this toolkit.
ANV Database Toolkit helps developers design LabVIEW API for querying various databases (MS SQL, MySQL, SQLite, Access). It allows to create VIs which can be used as API with the help of graphical user interface. When using these VIs, toolkit handles connection with the database, thus relieving developers of this burden in their applications.
It has the following features:
  • Simplifies handling of databases in LabVIEW projects
  • Allows to graphically create API VIs for Databases
  • Supports Read, Write, Update and Delete queries
  • Supports various database types (MS SQL, MySQL, SQLite, Access)
Overall idea is that developer could create set of high-level API VIs for queries using graphical user interface, without actual writing of SQL queries. Those API VIs are used in the application, and handle database communication in the background. Moreover, SQL query could be applied to any of the supported database types, it is a matter of database type selection. Change of target database does not require changes in API VI which executes the query.
After installation of the toolkit, sample project is available, which shows possibilities of the toolkit in terms of execution different types of queries.
Note, that in order to install the toolkit, VI Package Manager must be launched with Administrator privileges.
In case of any feedback, ideas or issues please do not hesitate to contact us either here, or at vipm.io, or at e-mail info@anv-tech.com.
Message 1 of 1
(1,968 Views)
