From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
controling different pins of serial port for isp programming
My application is to control different pins of serial port for isp programming.how to access these using labview7.
(3,217 Views)
A VISA property node will do the trick. Get one from the Instrument I/O>VISA>VISA Advanced palette. First right click and select Change Allto Write. Then, right click and select Properties>Modem Line Settings. There are only two output pins that you can control - DTR and RTS.
(3,217 Views)
