01-09-2014 07:06 AM
Hi everybody,
I want to read GPS data from Android tablet.
I have a gps code that is attached below.
Can you help me to test this code ? My problem is that I haven't the android program which is can send gps data to labview via bluetooth.
Please can you try to test this code with your android device if you have the android program, and help me to try it with my android tablet.
Best regards !
Thanks.
01-09-2014 08:08 AM
All of the subVIs are missing.
01-09-2014 03:20 PM
The code is incorrect ?
please tell me ! and if yes please help me what can i do to correct it .
Thanks .
01-09-2014 03:57 PM
I have no idea if the code is incorrect. You didn't attach all of the code. Each VI is a separate file and attaching the top level VI does not automatically attach the subVIs you are using. Zip up all VIs you are using and attach that.
Note: I don't think I want to mess with my android but if someone is feeling charitable, they will need all of your code.
01-10-2014 07:16 AM
Thank you for your responses.
I attach all VIs of GPS program below.
For the library of Android you can folow this steps:
01-13-2014 05:15 PM
I strongly suggest that you procure an android tablet so that you can test your program.
Undoubtedly you will need to test many times through the course of development.
01-14-2014 07:47 AM
thank you for your responses.
I have an android tablet, but it it hasn't a GPS program.
I ask is that the LabVIEW code work or not.
01-15-2014 03:35 PM
I also do not have an Android tablet with GPS.
I think you will find better results if you frame your question more narrowly. Find a specific problem and ask about that instance.
01-15-2014 04:10 PM
My curiosity finaly go the best of me and I downloaded the required library.
Your VI runs and the stop button works but thats all I know from doing that.
