03-31-2015 06:32 AM
I have a HAMEG HMS1000 spectrum analyser and i want to communicate with it using NI VISA and SCPI commands.
First i created a driver for my device with the informations given here : http://www.hameg.com/0.563.0.html. my device showed in the device manager under "NI-VISA USB Devices"
The problem is when i launch NI MAX i can see my device and communicate with it using "VISA TEST PANEL" but when i switch to labview, visa resource name doesn't show the name of my device.
did i do something wrong? please help
03-31-2015 09:01 AM
03-31-2015 09:08 AM
well yes i used the NI VISA Driver wizard to create a RAW usb interface, if it isn't much of a good idea should i use the windows drivers given by the vendor ? thank you again
03-31-2015 09:51 AM
