VISA Serial Read Error Heratherm OGH100
I am trying to communicate with a Heratherm OGH100 oven from laptop using USB-RS232 adapter. I am using the VISA Test Panel of NI -MAX to send the command.I am querying the oven with "?3010:00::c2\r" as mentioned in manual (\r for <CR>). But I always get a timeout error(see attached).
I have checked all the connection parameters:
stop bit :1
Parity: none
57600 bps
8 data bits
Can anybody please help me with this issue?
Sanhita
(2,615 Views)
Noticed you did not use the colon : after the ?.
-AK2DM
(2,607 Views)
I am so sorry that was a stupid error. Now I get the expected output however, I still get a timeout error. I need to fix that because I want to code this operation in Labwindows. Do you have some suggestions?
Sorry if this is a stupid question. Please excuse me as I am very new to this platform.
Sanhita
(2,585 Views)
Attaching the entire manual would be of help.
What specifically are you sending/doing that returns a timeout error?
-AK2DM
(2,553 Views)
I am trying to read the temperature of the oven using the commands given in the manual .I would ultimately like to develop a code to read the temperature of the oven automatically every 5 seconds.
 I have attached the I/0 trace too for reference. The same command does not work the first time I don't know why.
(2,498 Views)
Accepted by topic author sguha2
The issue was regarding the <CR>. A /n was getting appended every time which lead to the error.
Thank you.
(2,479 Views)
