VISA, Continuously read data when available.
I have pressure measuring device which reads the pressure periodically and sends information every 250ms. I would like to read the data for about one and half hour or even for some more time. I wrote 2 programs for this operation
1. VISA Read and write every 250ms: Here I configure the settings then write and read data every 250ms. (This fails after some time).
2. VISA using events.
I have attached the  both programs. Would you suggest which one is appropriate for this operation or any further suggestions, improvements???
Thank you.
Message 1 of 8
(4,934 Views)
I'm posting from my phone so I can't view the VI.
What error do you get? If the instrument appends a termination character, all you should need is a VISA Read with some arbitrarily high byte count. No VISA Bytes at Serial Port, no events, and no wait.
What are you doing with the write?
Message 2 of 8
(4,931 Views)
Error message is : -1073807339.
I found out that there is no need of VISA write. As soon I open the VISA port and set the port configuration the data is available on the interface.
I did even tried the example from ni here and I have the same error.
Message 3 of 8
(4,928 Views)
A timeout error implies one of two possible issues:
1. Your instrument does not constantly send out data
2. You are using the wrong termination character.
GCentral
Message 4 of 8
(4,915 Views)
What is the difference between the Serial Character and Serial TermChar  for the input: event type?
Message 5 of 8
(4,912 Views)
The Serial Character just means that something can into the serial port.  The Serial TermChar means that the Termination Character was found in the serial port.
GCentral
Message 6 of 8
(4,897 Views)
he issue has been solved.
Message 7 of 8
(4,873 Views)
can you give me code compatible for labview 2010
thanks
Message 8 of 8
(4,845 Views)
