Serial Write & Read.VI configure port error
On the Windows XP partition of my PC I can run the VI examples that use the serial COM ports. On the Suse/Linux partition however, most of the VI's run well, except those with serial ports, such as "Basic 2 Port Serial Write and Read.VI". They stop with the message: Error -1073807202 occurred at Property Node in VISA Configure Serial Port... The error code is undefined..."
(3,476 Views)
The error code means that VISA is not installed.
(3,465 Views)
I had the same problem and after intalling the VISA driver on my PC the problem was resolved. Try it .
Bye
(3,453 Views)
you can find the NI-VISA by clicking on the link:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0E91?opendocument&node=1...
Best regards
Alex
NI Switzerland
(3,440 Views)
