Serial Communication SubVI
Hello all,
I am new to this forum and LabVIEW in general. I have been playing with it for a couple weeks and have managed to make some simple applications for some of my devices. Now has come the time for me to make a larger VI so I am in need of figuring out how to make a subVI. I know you have to highlight what you need and then make it a subVI but I am having trouble figuring something out. I have some connectors which take in a VISA resource name and output it and the error in and out. When I select it though and make it a subVI the wiring  disappears. I would like the purple and yellow wires to be able to be connected to in the subVI because if I cannot then the program will be broken. It is meant to be a general Vi which will be reused. I have attached it so you can see the VI I am working with. As you can see in the PNG it has the output double but I also need the input/output resource name to show along with the error. Can anyone help me out?
Thank you.
(2,563 Views)
You didn't really supply any context with your posted VI.  It would possibly help if you supplied the subVI as well.  But if I am understanding correctly, I think you just need to not select the VISA Resource and Error terminals when you "create a subVI".
GCentral
(2,494 Views)
Im not sure what context I need but I just need to send a command for my temperature controller to read the current temperature. I communicate with it using serial communication. I am trying to make a subVI that reads for me and that can be hooked up to the other serial functions such as open and close. For this I need to make the attached subVI have the purple and yellow wires but currently mine does not and I cannot just unselect them as they are in the sequence structure. i have attached the subVI.
Thank you for your reply and help I really appreciate it.
(2,468 Views)
Accepted by topic author e.chavez
Well, nothing says you can't just manually add the parts and connect them up to the connector pane.  Here is a much cleaned up version of your code (remove the Bytes At Port, remove sequence structure as data flow will take care of it, added the terminals, simplified the reading of the value, changed your case structure into an array with an Index Array to acts as a simple lookup table).
GCentral
(2,459 Views)
Thank you! That is exactly what I was looking for. May I ask how you added the Visa and error in and the visa and error out like that? I'm still not all to familiar with LabVIEW.
(2,454 Views)
They are in the palettes.  Or you can right-click on the connector panes of the functions and choose to create control/indicator/constant.
GCentral
(2,447 Views)
