08-26-2019 12:42 PM
I am trying to send RS422 serial packets using NI PXI 8431/4 module. My goal is to send serial frame repetitively at 15ms interval, but sometime the packets are missing as they don't occur at next 15ms interval.
I have placed serial transmission VI inside a while loop and added a "wait ms" function to set the loop timing to 15ms.
Can you please guide me how to achieve desired repetition interval?
M Mahboob
08-27-2019 03:35 AM
08-27-2019 11:04 AM
How large are your packets and what baud rate are you using? What controller are you using and what OS is it running? How accurate do you need that interval to be?
08-27-2019 11:20 AM
Sorry, I should have mentioned the details earlier.
1. Packets lenght is in range of 2-3ms aproxx
2. Baud rate= 38400
3. Pxi chassis with embedded controller running Windows OS
4. Accuracy required is in mili seconds, desired is 15ms
M Mahboob
08-27-2019 12:25 PM
PS:
The chassis is PXIe-1071
Controller is PXIe-8821
