PyVirtualbench MSO: Error 374309 Not enough memory was provided to complete the operation.
Hello everyone,
I am using the Virtualbench 8054 and downloaded the pyvirtualbench software from github as master. A more recent is not available then I am using. I have run into some error with the Example code. When I want to enable more than one channel, or any other channel then 1, like this:
                mso.configure_analog_channel('SN/mso/1:2', True, 10, 0, 10, 1)
I get this message
Error/Warning 374309 occurred
NI-VirtualBench: Not enough memory was provided to complete the operation.
This message comes when it is trying to read_analog_digital_u64.
On the NI Virtualbench software 2 Channels are enabled and visible. Please help how to solve this issue?
(1,033 Views)
Dear annasinam,
Python wrapper is not officially developed for this specific device and may lead to this kind of errors. I did not encounter any problems when I used LabVIEW for this. Maybe it is because of the libraries used by python or something that fills up the memory. Anyways this is a step by step guide for doing so with LabVIEW  if you are interested.
best,
anasei.
(926 Views)
