NI XNet .dbc to FIBEX conversion
Hi Friends, I am using NI XNet version 18.5. in my PC. When i am trying to convert .dbc file to FIBEX or .xml (i.e cluster format) i am facing some issue. When the file is converted from .dbc to .xml file the Frame names and Signal names whose string length is more 32 are clipped and it is saving with 32 string length.
Example : Actual name in .dbc : Active_Lane_Management_Switch_Start
                After Conversion .xmlActive_Lane_Management_Switch_St
from above you can see "art " is missed.
Can anyone help in this regard how to overcome this issue.
Message 1 of 1
(1,886 Views)
