Our online shopping is experiencing intermittent service disruptions.
Support teams are actively working on the resolution.
05-09-2018 09:14 AM
Awesome!! Was it the force reinstall of NI-VISA that solved the problem?
05-16-2018 04:34 AM
yes. force reinstall of NI-VISA 17.5.
I did a force reinstall previously which did not solve the problem, but possibly, (I'm not very sure) I force reinstalled not that last available version. I also cleaned up as much as possible before that last succesfull force reïnstall.
05-17-2018 03:39 PM
If your problem has been solved, then please mark message 8 where the idea was given as the answer and Kudo any other entries that helped you towards the solution.
08-23-2018 09:19 AM
I kudo'd the member who has posted msg 8 but am unable to mask as anwser
I think It's for the originator of this message thread to mark msg 8 as the answer.
07-02-2019 11:23 AM
I had the same issue, however I could not perform a force-reinstall because I installed from the NI Package manager, rather than from individual setup files or disk images. I attempted to uninstall/reinstall NI VISA with the NI Package Manager but still got the VISA error. What corrected the issue for me was this: I went and confirmed the following three files were on my system, and none were from third party manufacturers (by checking Properties --> Details):
c:\windows\system32\visa32.dll
c:\windows\system32\visa64.dll
c:\windows\SysWOW64\visa32.dll
The third file was missing. There was a version of it called visa32.dll.restore, however removing the word "restore" at the end did not fix the issue. I found the file on a different computer running Labview, copied it over, rebooted, and everything worked.
For what it's worth, on my setup, if I check Properties --> Details on the first two files, they are from IVI Foundation. The third is from NI.
09-04-2019 07:24 AM
Hey,
I worked with LabVIEW 32bit on Windows 64bit Windows10
sorry
