NI-DAQ NI-9266 Read Open Open Current Loop status bit attribute
Hello everybody,
I am currrently coding an application in Labwindows CVI 2019 to control NI-DAQ sourcing current NI-966 modules racked in a cDAQ-9185 Ethernet chassis. Thos modules are connected to LEDs. I would to know if there is a connection problem on LEDs. Therfore I used DAQmxGetReadAttribute function with DAQmx_Read_OpenCurrentLoopChansExist attribute. The function returns the following message :
"return value == -200452. Specified property is not supported by the device or is not applicable to the task. Property DAQmx_Read_OpenCurrentLoopChansExist
Task Name : (...)
Status Code : -200452
Modules and chassis are defined in NI-MAX in simulated mode.
Thanks in advance for your help.
James
(678 Views)
NI-9266 specifications did not mention that you can read the open-loop status. Did you see it documented that you can read from software the open loop alarm?
Santhosh
Soliton Technologies
(652 Views)
Hello Santhosh,
I read it in NI-9266 Getting Started - NI
(right click and open the link). In section "Current Loop Status".
James
(648 Views)
Oh, not all features of DAQmx run in simulated mode, hence the error.
Please post if you still observe the error when running with real hardware.
Santhosh
(630 Views)
