MAX doesnot see devices which are connected to GPIB-ENET/100
Hello
I cannot see GPIB devices, which are connected to the GPIB-ENET/100, with MAX (Measurement and Automation Explorer). The ENET has a valid ip-adress and I can ping it from my PC. I also open the necessary firewall ports.
My MAX version is 3.1.1.3004
Best regards
Christian
(2,682 Views)
hi
do you use the latest firmware for GPIB-ENET/100, you can find it here: http://digital.ni.com/public.nsf/allkb/F4F7F2F74A60819A862569DD0071180F
You can also try to download the newest NI- GPIB 488.2 driver. Link:http://digital.ni.com/softlib.nsf/MainPage?ReadForm&node=132010_US
Deinstall the old one and install the newer one without hardware, if you use a older driver.
After installing the new driver connect the hardware.
If it's problem with MAX itself, you can try to repair MAX. Go to Start->Settings->Control panel-> software -> click NI-Software change/delete. In the next window choose Measurement&Automation Explorer and click repair.
best regards.
Christoph Strasser| AE NIG
Message Edited by ChristophS on 05-15-2007 03:48 AM
(2,665 Views)
