08-05-2022 03:14 AM
Currently I am interfacing Programmable power supply (BK Precision 9205) to my test PC, in order to send SCPI commands to Power supply it requires NI-VISA drivers. can any one clarify that the NI-VISA is available at free of cost ? or it is licensed?
M.Sakthivel.
08-05-2022 11:41 AM
Drivers are free to use, you can download them from the NI website.
08-05-2022 11:48 AM
More specifically, download them from here: NI-VISA Download
08-23-2022 01:40 AM
12-17-2023 06:04 AM
I have the same question and am a little confused. I have read, that the driver is free. However here: https://www.ni.com/de-de/shop/product/ni-visa.html I can buy the driver. Now what is the case? Is it free, or do I need to buy it?
12-17-2023 07:22 AM
It has never needed to be bought before. I am in the act of updating a test PC to make sure NI-VISA 2023Q4 does not need a license (it had 21 installed).
12-17-2023 12:18 PM
My test laptop does not show a license being required for VISA. So I would still assume it is free to use.
I did also pose this question in a private board that will hopefully get the attention of some higher ups in NI.
12-17-2023 01:36 PM
Thank you very much for assisting! I also have installed it from your link, and there where no obvious mentions of the need of a payed license. Just want to make sure I'm not doing anything illegal 😄
12-17-2023 05:53 PM
NI-VISA is not free.
If you are not using it in conjunction with NI software or hardware, you will need to purchase a license.
(There is no serial code or activation when you purchase a license. You will only be issued with a proof of purchase.)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7OLSA0&l=ja-JP
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/NI-VISA-licensing-policy/td-p/2382668
12-20-2023 04:19 AM
Thanks for the links. I feel like they should communicate that more clearly when installing. @crossrulz do you have any responses so far?
