03-30-2015 07:36 PM
Hi Labview users
I have 3852A DAQ, which is connected by GPIB-USB-B. It's data scanning/updating speed is lower than expected. It's reading 32 data (23 of thermocouple, and 9 of analog voltage), and the data updated every 2 seconds (While loop is set to run as fast as it can). When it reads smaller number(2 or 3) of data, it runs faster. I want to know if there is any way that I can increase the data scanning speed faster than every 2 seconds. I attached my VI for review. Thank you.
03-31-2015 02:03 AM
Your program can be simplified a lot, but probably the speed is determined solely by the measurement speed of the HP.
Not that bad for a multimeter that has to read out thermocouples at good resolution anyway.
So first check the measurement speed, and than try to add more multimeters to speed things up.
