03-02-2006 06:38 AM
03-03-2006 09:58 AM
Hi Shamboy,
Thanks for your query for RACAL drivers.
All of the drivers NI have had submitted are held on the idnet section of our website, which you can find at www.ni.com/idnet. Here you can search for drivers by manufacturer and equipment type.
I've had a quick look for the RACAL 6113, and can't find a driver posted there yet. You may be able to take a prebuilt driver for a similar piece of equipment and modify it slightly to achieve the functionality you want, if you know the basic command set for the instrument. Alternatively contact RACAL directly and see if they can build one for you.
I hope this helps slightly with your search!
Best wishes,
Mark
Applications Engineer
03-03-2006 10:51 AM
Hi Mark, Ya thats what I am currently doing is modifying another driver to suit. Thanks for your help.
regards,
Jim.
03-06-2006 04:52 AM
Hi Jim,
Thanks for your reply, good luck with the modifications! If you end up writing a full driver for the RACAL unit, please consider submitting it to the idnet portion of the website if possible, in case it may be useful for other customers in the future.
Best wishes,
Mark
