GPIB download file from Oscilloscope ?
I am using a PC which communicate with an Oscilloscope via GPIB.
I would like to know if a C++ command exists to download a file from the Oscilloscope to the PC.
Devices: Oscilloscope Tektronix 5054B
                Programming C++ Builder 6.0
Thank you
Matthieu
(2,660 Views)
C++, VB, LabView, etc. have nothing to do with the commands that the scope supports. You need to find the command in the manual for the instrument and then you can issue that in any language you want.
Which I believe is the same answer you got at  http://forums.ni.com/ni/board/message?board.id=4170&message.id=14068#M14068
Message Edited by Dennis Knutson on 04-28-2007 11:43 AM
(2,655 Views)
