GPIB-ENET/1000 LAN Cable
I am trying to set up GPIB_ENET/1000 on a windows 10 PC. I am not sure (As it is not very clear in the manual)  I have to use cross-over LAN cable or straight LAN cable from my PC LAN port to GPIB-ENET.
(789 Views)
If you're connecting directly to a PC, use an Ethernet cross-over cable and a direct cable if connecting to an ethernet hub or router.
If you got a local network, just use a regular ethernet cable to connect the GPIB-ENET to the ethernet socket.
Santhosh
Soliton Technologies
(774 Views)
Below image shows details of my board
I followed the steps described in GPIB-ENET-100_install_notes document but not able to talk to  GPIB-ENET board. After CFG reset, how to find IP address of GPIB_ENET1000?. I tried ping NIENET12188D9 and not getting connected.
(754 Views)
The board I have is "Revision 1.1" and is almost 10 years old. As I am using Windows 10 to talk to it, just wondering whether my GPIB-ENET supports Windows 10?
(745 Views)
