07-14-2014 05:47 AM
I am getting this error as ""Error: Property Node (arg 1) in VISA Configure Serial Port""
in my VI
I am not able to locate the problem..
please help out.
07-14-2014 07:35 AM - edited 07-14-2014 07:36 AM
Did you specify a VISA resource name? If that control is empty, I get error 1. If I specify an invalid name, I get error -1073807343.
Also, ou do not need the sequence structure.
Lynn
03-30-2015 10:19 AM
I'm also encountering this issue; did you ever find a solution?
03-31-2015 10:29 AM
The solution is to make sure you have the COM port selected in the visa control
