Duplicate GPIB address
It seems that all 0~30 addresses are used, but actually there is only one device.
I don't know why.
(1,435 Views)
What GPIB card do you use?
Worth resetting the NI MAX database.
Santhosh
Soliton Technologies
(1,423 Views)
Looks like your device uses Secondary Addresses.  While uncommon, it is a valid GPIB setup.  Can you supply more information on the device you are trying to communicate with?
GCentral
(1,417 Views)
Thank you for your reply.
The GPIB card is Keysight-82357B, and the device is Keithley 2410.
I've encountered the same situation twice in the past ten years. The last time is NI-PCI GPIB cards + Kepco power supplies.Keysight-82357B.jpg
(1,400 Views)
I never know the trigger condition of the secondary address. Actually, only GPIB0::24::10 INSTR is valid.
The equipment combination is keysight-823578 + Keithey 2410.
It seems that GPIB card is constantly looking for device address...
(1,398 Views)
You should just send and receive commands from "GPIB0::24::Instr" in your case. Ignore the secondary addresses with all Keithley instruments.
(1,371 Views)
Thank you.
I think you are right.
The problem is that the list of device addresses is too long to find a right one if there are more instruments, so I want to clear it.
Do you have any suggestions?
(1,358 Views)
