09-01-2010 09:38 AM
I'm new with LabView and I try to communicate with a Hameg 1008-2 oscilloscope. I installed the osci in the Measurement & Automation Explorer with device type "TCP/IP Raw Socket". If I start the VISA Test Panel for the instrument I can communicate with the osci. For example if I write the *IDN? command I get the instrument name, version and so on. Now I tried to create a VI with the same configuration but in VISA read I don't get an answer but the error message 0xBFFF0015 (connection time out). Additional I tried to create the VI directly with TCPIP Protocol and tried same other configurations for TCP/IP RAW with the some results.
For more details see the attached VI.
I'm thankful for any help
Michael
09-14-2010 04:15 AM
Hello MichaelWetzel,
in your case I assume you should have time delay between your write and read VIs.
Please have a look at the following example:
Basic Serial Write and Read.vi
Your VI:
12-17-2014 10:24 AM
Hi Michael,
Did your program worked finally? I am having same problem, could you share your file ?
sumit
04-23-2015 05:45 AM
hi, we are trying to communicate hameg hm1008-2 oscilloscope with labview using USB. but we still can't get any signals please any help or advices
04-23-2015 07:59 AM
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
