Cant access Keysight N6700c power supply
 We have a Keysight N6700C power supply installed on our Linux box running RedHawk 8.4 (yes.. yes, I know not supported OS but that does not get me a solution). We tried to run a LabView program that has worked for us in controlling the N6700C before in a windows environment. We recompiled it on the Linux box but it would not work.
In order to simplify debugging of the problem (as the above program is a lot more complex) we made it simple by putting 2 Visa blocks... a find resource and a Visa Open. They both give the same error alluding to VISA or a code library required by VISA could not be located or loaded or a required driver not being installed. See the uploaded image
Any suggestions on what to try or what could be missing in the installation?
We have the following packages installed:
labview-2023-exe-libs.x86_64                      23.3.1.49155-0+f3              @ni-labview-2023-el8-full
labview-2023-profull-exe.x86_64                   23.3.1.49155-0+f3              @ni-labview-2023-el8-full
Thankyou for any help you can provide.
Message 1 of 1
(711 Views)
