Cannot connect to Arcus DMX-ETH through ethernet
I cannot connect to this stepper motor through ethernet in MAX.  I have turned off the firewall and given my computer an IP address on the same subnet.
(5,442 Views)
(5,441 Views)
How do you have the device connected?  I would recommend using a crossover cable directly to the computer.  Can you ping the device, or communicate with it using any software provided by the manufacturers?
Have you taken a lookat this tutorial for using Ethernet devices with VISA?
-Christina W.
(5,423 Views)
I have the device connected with a crossover cable directly to the computer and I cannot ping it or communicate with the VB software provided by the manufacturers.
(5,419 Views)
If you can't ping it or use the vendor's software, I don't see how this is a problem in MAX or anthing related to NI software. What does the vendor recomend you do?
(5,410 Views)
I am having the same issue. I connect a crossover cable. I can ping it. I start the ARCUS SOFT-EXE-PMX-4ET-SA-131 software supplied by the vendor and the software comes up correctly for about a second and then crashes. I have had this issue with other models of the motor too. I try to use MAX to establish a VISA TCP connection with a port of 5001 and it is validated, but then has a red x. Finally, I use PuTTY and I can communicate with the controller using a raw connection, but as soon as I send the wrong command, mispelled command or invalid command, the controller disconnects form the session. I can restart the session and continue sending commands. Their VB software is of no use for TCP connections.
(4,033 Views)
I give you the same advise as Dennis did but more explicit.
Contact the supplier and tell them their software stinks.
(4,026 Views)
