01-28-2011 03:53 PM
i am trying to use a 54522A oscilloscope on Lab view.
i grabbed the driver below and tried to use that program to read the oscilloscope on the computer through a GBIP connection. i ended up getting this warning:
the driver is located here.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1120
can anyone tell me what this is and if you can what i can do to fix this? (i am very unexperienced with labview this is my fourth or fifth time doing it)
01-28-2011 04:35 PM
here is a better pic. of it.
it says
Load and Save Warning List
History
1/28/2011 4:16:44 PM ==Loaded HP 5452XA Read Normal-Avg Waveform.vi
details for Top-Level Item
Loaded from path: C:\Documents and Settings\Tom Colbert\Local Settings\Temp\Temporary Directiory 2 for
hp5452xa.zip\HP5452XA.LLB\HP5452XA Read Normal-Avg Waveform.vi
types Items (-these are the tabs)
(under types)
Warning Types
Dependency loaded from new path (2 warnings affecting 2 callers)
Details
Expected Dependecny Path New Dependency Path
<instrlib>:\hp5452xa\HP545XXA.LLB\HP545XXA Recieve Message.vi C:\Documents
andSettings\Tom Colbert\Desktop\drivers
for research\HP545
Affected Callers
C:\Documents and Settings\TomColbert\Local Settings\Temp\Temporary Directory 2 for hp5452xa.zip\HP5452XA.LLB\HP5452XA R
01-28-2011 04:59 PM
Install it to the correct location. There are instructions on the download page. The expected path is even shown on the screen you posted.
01-28-2011 06:12 PM
thank you.
