16-bit application fails to to communicate in Win7
We've got a legacy 16-bit application (written in Borland C) that is in the process of being re-written  (due in ~6 months). In the meantime however, we're also being forced to upgrade our OS to Win7.
The 16-bit app works on our XP machines. It communicates with a Keithley 7001 switcher and  2002 DMM via USB-GPIB-HS.
However when we try to run the app on Win7 we initially get the error: "can't find gpib.dll".
We tried copying gpib.dll from an XP machine with the following results:
- When trying to run our app it fails immediately with an assertion error from the "send_data" method.
- When trying to register the .dll we get the response: "The module may not be compitiple with the version of windows you're running..."
Any help to get this app "across the finish line" is greatly apreciated.
Jon
(2,870 Views)
(2,845 Views)
I installed NI-488.2 3.1.1 - that was the trick!
From the documentation:
Enhancements and Bug Fixes in Version 3.0
DOS and Win16 Support
Previous versions of NI-488.2 for Windows did not install DOS and Win16 support on Windows 7 or Vista
Thanks a bunch!
Jon
(2,830 Views)
