I have three items on the same network.
1: LabVIEW Development PC
2: Raspberry PI
3: Ethernet DAQ Device
LabVIEW Dev PC can connect to and deploy code to Raspberry Pi.
LabVIEW Dev PC can connect to DAQ device using VISA (TCPIP0::XXX.XXX.XXX.XXX::34434::SOCKET) and read data.
Raspberry Pi can Ping the DAQ device.
Again, running the DAQ VI on my Development PC works as expected.
PROBLEM: If I change the target to the Raspberry Pi and execute the code, the code errors out with "VISA: (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system."
Any thoughts on why this is happening? Could the Raspberry Pi be blocking the port?
Thanks in advance for the assistance.
