05-03-2022 11:42 AM
Hello, thank you for reading me, I´m trying to do a 3 led sequence and send it to a arduino with also 3 leds but the sequence is not working on the physical leds
05-03-2022 12:31 PM
Basic dataflow problem!
Your sequence runs in parallel the the DAQ train, each runs once per iteration of the while loop. You don't need any local variables at all here!
05-03-2022 12:38 PM
Your ABC should not be controls if you are using them as indicators (to be changed by the code instead of the user.)
I don't have your hardware, but here's a quick draft. (I am sure things can be simplified quite a bit more).
05-04-2022 06:33 AM
just got the code, and added linx
