I'm trying to use Rapsberry 2B with LabVIEW 2021. All seems properly installed, I've installed LV21 on raspi since (Tools>Hobbyist>Target Configuration). Here all seems to be OK.
Only one comment : Connection doesn't run if I use hostname instead of IP.
Then I can n a new LV projet, and add the raspi as target. LV find it.
But impossible to connect it to the projet (right click on target, Connect). I've tested o create a new user, with default value (pi - pw raspberry) and sudo privileges, but same behaviour.
I work with LabVIEW Professionnel Development System Version 21.0.1f2 (32-bit). I've installed hobbyst/linx tollkit x86 version 21.1. Raspi is connected on my computer with an ethernet cable, I've checked it with putty it's OK. I share the web connection of my smartphone activating usb-modem, internet connexion is OK.
How explain the connection error ?
Thanks in advance for your feedback!
Francis M
