10-04-2022 04:35 PM
I am trying to connect to the internal Arduino Leonardo on a LattePanda Delta board. The Arduino is on COM4 as shown in Device Manager.
I can also see the Arduino board info.
In NI MAX the Arduino is showing up on COM 4 (ASRL4)
When I use the Firmware Wizard I get a message that it is complete, But when I view the Log I see that it could not open device.
I looked at similar problems and updated the Packet Number.vi but I don't think it is going to work until I get the firmware installed.
Is there any way to confirm that the firmware was installed?
Are there alternatives? Like using VISA communications?
I only need to toggle four digital outputs lines.
Any help would be greatly appreciated.
10-05-2022 05:52 AM
i never used an onboard arduino with Linx. Are you running windows in the lattepanda? perhaps something in OS might be blocking direct access. you may need to investigate. also i am not sure if LabVIEW 64 bits allow using LINX, but you need to try.
if you need a faster solution, then VISA is your friend. you can read and write data from/to arduino using a conventional sketch (not LINX firmware in exemple)
03-07-2023 05:47 PM
Just replying to see if you found a workaround to this issue. I'm currently experiencing the same thing using LabVIEW 2023 and a LattePanda 3 Delta. I'm able to write to the pins through the Arduino IDE, but I can't seem to upload the LINX firmware through the firmware wizard as well.
03-08-2023 07:33 AM
I was not able to load the Linx firmware. I found a workaround by writing arduino code to respond to serial input. LabVIEW code to send serial data. LabVIEW sends 'A', arduino sets D2 if 'A' is received.
03-09-2023 05:51 PM
I don't know if this is still relevant to you, but I figured I'd post it in case anybody else runs into a similar issue. It seems like a similar workaround to what you did.
I used the Build with Arduino IDE option (fig1). I specified the LINX and Arduino path (fig2) and then hit "Generate" which populated a LINX subfolder in the Arduino libraries folder.
The populated LINX folder contains multiple sketches under "examples". I opened and uploaded the Arduino_Leonardo_Serial.ino file through the Arduino IDE. NI Community doesn't seem to allow uploading .ino files, but here's an example path for the file:
C:\Users\LattePanda\Documents\Arduino\libraries\LINX\examples\Arduino_Leonardo_Serial
I was able to toggle the pins through the LINX LabVIEW examples once this sketch was uploaded.
04-07-2023 07:10 PM
I'll follow what you said.
But the LV2021 pop-up prompt is shown in the above image.
My arduino IDE Version is 2.0.4.
04-07-2023 07:25 PM
This is my “.ino” file. I failed in uploading.
04-14-2023 12:48 PM
I followed the steps detailed here: https://www.labviewmakerhub.com/doku.php?id=learn:tutorials:libraries:linx:misc:porting_device.
However, I didn't bother creating new files and just overwrote the files corresponding to the Arduino_Leonardo_Serial.ino file to correct for the number of pins on my LattePanda.
