Hobbyist Toolkit
Is there a way convert Boolean 2d array to 1d boolean array
Hello, presently doing one project I need help(How to convert Boolean 2d array to 1d boolean array?
(1,428 Views)
As this is a basic LabVIEW question I would post it in the LabVIEW forum as you will get a quicker response.
Though, here is what I believe you are looking for.  This will also work with a 3D to 1D array also just by changing the input array size.
David Wilt
The New Standard LLC
(1,403 Views)
Slight edit here.  You don't actually need the FOR loop.  You can just use Multiply Array Elements (in the Numeric palette) instead.
GCentral
(1,399 Views)
Thanks, I did a quick look for that function and did not see one so used the For Loop.  Learn something new every day.
David Wilt
(1,395 Views)
A "boolean array" is green, not orange, so you need to read between the lines....
Still the shown solution should work for all datatypes. 😉
You could even make it into a malleable VI (*.vim) so it works for inputs of any number of dimensions and datatypes (within reason!), always resulting in a 1D array.
Another option would be to use a FOR loop and concatenating tunnel. (Same result, but 2D to 1D only).
(1,371 Views)
I completed missed that it was a boolean array.  I used a double.  Wow I guess it was too early this morning and I should never try to answer questions before my coffee.
David Wilt
(1,367 Views)
