Hobbyist Toolkit
Interfacing Labview with Teensy 4.0
I have recently started a project in which I need to use a Teensy 4.0 board. Because I am familiar with Labview and not much with Arduino, I thought I could try to use Labview. I want to develop some code for sending signals and reading data from sensors.
I installed the LINX package from MakerHub, but the Teensy 4.0 is not listed and I am not sure if I need to adapt something for the 4.0 or there is something already available.
Can anyone help?
Thank you in advance!!
Message 1 of 8
(3,314 Views)
Accepted by topic author massic76
Hey massic76,
have you tried this tutorial?
https://www.labviewmakerhub.com/doku.php?id=learn:tutorials:libraries:linx:misc:porting_device
this may help you adding new hardware to LINX.
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
Message 2 of 8
(3,228 Views)
Hi Jorge,
Thank you very much! I will definitely take a look at that tutorial. I didn't know about it.
I will report back once I try it and see if I am successful.
Best, Massimo
Message 3 of 8
(3,225 Views)
just a heads up,
i don't know the reason that you need to use Teensy 4.0.
As far as i understand, it is a very powerful hardware.
However LINX may slow it down in terms of using visa connection and other functions to read/write signals.
Sistema Fiep
CLAD, CLD
Message 4 of 8
(3,223 Views)
Hi Jorge,
Yes, you are totally right. I have thought of that. I have seen a comment about this in another post and it make sense.
We are using the Teensy 4.0 to control a motor for actuation of an exoskeleton. I need to send command signals and do readouts of the sensors that come with the motor. We also have a combination of analog and digital sensors that we want to monitor for proper actuation of the system.
After reading that post and also based on your last comment, I may try to program the Teensy 4.0 and test the correct operation and maybe use Labview to start and stop and collect data with a GUI.
If you have any other thoughts or comment, please feel free to share them!
Thank you for the help so far.
Massimo
Message 5 of 8
(3,221 Views)
oh well, then i'll share an experience i had.
I needed to acquire an 1kHz signal with these development cheap boards. as you may know, it is very hard for such hardware make such acquisition and aditionaly deal with communication and so on.
Our solution:
Arduino Due acquiring data <--> serial low level communication (point to point, very fast) with ESP 32
ESP32 gets data, build an 400 position array, sends over TCP to a listener in LabVIEW.
even though we didn't use LINX, it was a very good experience.
Sistema Fiep
CLAD, CLD
Message 6 of 8
(3,216 Views)
Hi Jorge,
Sorry for the late reply. Thank you for sharing your experience. I will look into the setup that you shared and see if we can go with such solution.
It seems that your solution worked quite well.
Best, Massimo
Message 7 of 8
(3,182 Views)
Hello everyone,
Jorge helped me by suggesting a post on how to add LINX support for the teensy 4.0.
The link he provided is: https://www.labviewmakerhub.com/doku.php?id=learn:tutorials:libraries:linx:misc:porting_device
I have been working on the list of changes to be made to the .cpp and .h files for the libraries.
However, I tried to find some information about the Teensy 4.0, but I am not sure what I should put for the following variables/definitions. If any of you knows what I should put for these variables/settings it would be great. Thank you in advance.
  • Number of SPI Speeds: Update NUM_SPI_SPEEDS with the number of supported SPI clock rates.
    I am not sure about the SPI Speeds because it seems that both ARDUINO (https://www.arduino.cc/en/reference/SPI) and Teensy (https://www.pjrc.com/teensy/td_libs_SPI.html) recommend not to use SPI Speeds definitions and dividers. They seem to recommend to use SPISettings with SPI.beginTransaction() to configure SPI parameters. In this case, I am not sure how to adapt the sample .cc and .h files.
  • Number of UART Channels: Update NUM_UART_CHANS with the number of UART channels on the device.
  • Number of UART Speeds: Update NUM_UART_SPEEDS with the number of supported UART baud rates.
Also in the Config.h I am not sure about these changes:
  • Set the device family code
    What is the family code for the Teensy 4.0? Where can I find it?
  • Set the ARDUINO_VERSION to match the IDE version used to build the firmware. This is used to deal with some API changes in the different wiring versions.
    For the Teensy 3.0 and 3.1 the version was set to 105. I currently have the 1.8.15, do I need to put something related to this or just leave the 105?
Thank you in advance for your attention to this post and for your assistance.
Best, Massimo.
Message 8 of 8
(3,066 Views)
