If I run something like the example here:
C:\Program Files (x86)\National Instruments\LabVIEW 2021\examples\File IO\TDMS\Standard Read and Write\TDMS Write Events Data.vi
I get an error 2519. I get this error on two different RPis. I did not see this issue with LabVIEW 2020
LabVIEW: (Hex 0xFFFFF629) LabVIEW could not load the TDMS file component.
Maybe I need to also update some TDMS component?
