07-25-2021 03:13 PM
I would like to build a test setup where I use 2 or more ChipKIT WF32 boards and communicate wirelessly with PC using LabVIEW and the LINX toolkit. This is pretty straight forward with one ChipKIT WF32 board, but will it work with several boards where each board has a unique IP-adress? Each of the boards will have to send some analog values from different location to the same LINX program on PC. The boards are quite expensive, so I would like to know before order more of them;)
br,
paalbrok
07-26-2021 02:51 AM
I have no experience with the chipkit but would expect it to work if they allow to configure the network settings somehow. Will of course require some basic network knowledge and likely some command line commands..
That all said, did you notice that the Chipkit WF32 has been discontinued by Digilent. It seems still available by some distributors but may not be a prudent choice for a new project.
07-26-2021 01:24 PM
Yes, I saw it was discontinoued, but still possible to get.
