11-17-2022 09:20 AM
Hello All,
I can successfully connect my Beaglebone Black to LabVIEW using the USB connection on 192.168.7.2 but the RJ45 must also connected to my home router and the internet. I can build a startup vi and it runs perfectly. I can also power cycle the BBB and all is well, but if I remove the RJ45 connection and power cycle the BBB the startup vi will not run and only runs after the RJ45 is reconnected and another power cycle. Unfortunately I need the vi to run on the BBB in a pure standalone way with only power supplied. Any help really appreciated.
03-15-2023 11:21 AM
I have the same issue. I don't know if this is the intended behavior, but I thought I'd add some more context to the issue. The following is using a modified Blink.vi so the light blinks on its own.
Mar 15 15:39:01 beaglebone NISysServer.py[1542]: 127.0.0.1 - - [15/Mar/2023 15:39:01] "GET publish?Main%20Application%20Instance%2fRTServiceName=HTTP%2f1.0%20200%20OK%0d%0aServer%3a%20Service%20Locator%
03-15-2023 04:31 PM
Activated LV 2023 (non community edition), this was not the problem.
03-17-2023 02:54 PM
So I worked around my problem by reverting to Labview 2020 SP1. This version lets you install the 2020 version (20.0.0-4) of the Beaglebone Labview software to the board. Now it will boot and run the blink.vi code without an internet connection. Unfortunately, you cannot deploy from Labview 2023 using this version.
I assume the problem is either the 2023 version of the Beaglebone Labview software, or some library that comes with Labview I had when I installed Labview 2023 that somehow stuck with the VI when I deployed it.
03-22-2023 11:44 AM
It would be interesting to capture the output of 'systemctl status labview.service' in both scenarios (internet connection and no internet connection).
Here's a thought:
The labview.service file that instructs systemd to start LabVIEW on boot, has this line:
After=network.target
That line is supposed to mean that LabVIEW will wait to start until the network stack is initialized, not necessarily that there is an internet connection. But it makes me wonder if it has something to do with it.
As an experiment the labview.service file on the target (/etc/systemd/system/labview.service) could be edited to remove the "After=network.target" line to see if it clears up the problem.
