06-25-2008 07:04 AM
Hi
I have two arrays with xy-plot data that I want so save to a tdms file and also
write some further information about the plot. When I couldn't get this to work
in a built executable I scaled down the problem and found that there was
problem with LabView tdms and runtime engine. I can't write channel names when I’m
saving channel data, it doesn't matter if I’m writing a group name or not.
I've attached two printscreens of my application; the top one doesn’t create
any tdms-file after being compiled but works fine when I run it in LabView. The
bottom application creates a file when I’m running it but results in a pop-up LabView
error that shows a memory error (memory.cpp, line 342, LabView 8.2.1).
Code compiled in LabView 8.2.0.4002
Runtime engine 8.2
Is there any better solution for what I want to do? Or any solution of the runtime problem?
07-05-2008 03:22 PM
07-06-2008 06:41 PM
07-07-2008 09:51 AM
07-07-2008 10:13 AM
