01-03-2009 08:19 AM
Can someone help me calculate the smallest change in weight I will be able to read with the cfp-sg-140 and a 10 lbs load cell with a 10 volt excitation and 3mV/V output. I know this module is 16 bit 2^16, but how do I translate this to pounds or grams??? How about if I use a 5 lbs load cell??
Thanks a million in advance for your help....
01-03-2009 08:58 AM
Have a look at page 9 of the following document:
01-03-2009 07:29 PM
The manual explains the scaling procedure but I dont have any doubts on that.
I actually meant the smallest change that the cfp-sg-140 will detect with that kind of load cell. Do you know the resolution that I will be able to get out of such configuration????
01-03-2009 09:10 PM
Just do the math.
You would need the 3.5 mV range for a 3 mV/V input. 1/2^16 x 3.5 mV/V is 1 part in 65536 is .0534 microvolts/V
Take that times 10lbs divided by 3 mV/V = 1.78 e-4 lbs
