09-28-2006 09:05 AM
10-02-2006 08:46 AM
10-03-2006 08:39 AM
10-04-2006 10:21 PM
10-10-2006 10:52 AM
10-10-2006 10:40 PM
10-10-2006 10:47 PM - edited 10-10-2006 10:47 PM
Message Edited by NathanT on 10-10-2006 10:47 PM
10-11-2006 10:28 AM
10-12-2006 11:33 AM
Hello Sunswam,
That is a really interesting question. Here is a knowledgebase that allows you to lower the resistance by adding a parallel resistor. It also lists the equiation which is 1/Re = 1/R1 + 1/R2.
http://digital.ni.com/public.nsf/websearch/C200644052C8BD5B86256CB8005A24D1?OpenDocument
Anytime you are noticing strange behavior in FieldPoint, make sure that the same results happen in Measurement and Automation Explorer. What voltages is it measuring instead? Can you short the voltage in with the ground and get 0 Voltes?
I hope this helps,
Steven T.
10-16-2006 03:22 PM
