11-14-2007 08:58 AM
11-15-2007 01:58 AM
Hi Doug,
the definition of the advise rate is.
"Advise Rate: In the background, the FP Advise function polls the module at a set interval until there is a change. Once a change in value is detected, the FP Advise function returns the changed value to the FieldPoint Server."
This means that if your advise rate is higher than your read rate, it will affect the speed of your module.
Hope it helps
11-15-2007 08:43 AM
11-19-2007 09:40 AM
Hi again Doug,
the advise rate is in the background no matter if you use the function or not.
