09-23-2008 09:46 AM
I'm using the cables in an application that needs to know the types of material used in the Accessory cables. Do we have any hazardous chemicals? What is the flamability rating? Do we have low smoke halegen materials? What is the plating material and thickness of the pins in cables, etc,. Where do I get this information ASAP.
09-25-2008 10:17 AM
Can you specify which cables you will be using?
The cables are normally not intended for very high voltages, so please give a description of the application as well.
Measure It. Fix It. ni.com/greenengineering/
NI Vision ni.com/vision/
