06-13-2018 04:20 PM
Has anyone ran into problems with the timestamp not updating in MAX? It will only update after I start then stop the panel.
This is happening on a Quad-510 only, all the other modules in the bank seem to be working fine.
06-14-2018 05:00 PM
Hey,
Does the correct data show or is it only the timestamps that are not acting correctly?
-Brian J.
06-15-2018 09:07 AM
I can't tell if the data is showing correctly.
It's supposed to be counting pulses, but i don't see any counts updating.
Having to start and stop to update the timestamp probably resets the pulse count if there is any.
07-03-2018 01:31 PM
Hey sorry for the late reply. How are you generating the pulses? If you are still having this issue.
-Brian J.
07-05-2018 11:53 AM
Hello BrianJ,
No worries about late replies, any help is appreciated.
Pulses are coming from a rotary type index on a gas meter. I thought that it was emitting a voltage when I hooked my multimeter up to it, but that may just be noise in the line or something.
I later found out that it is a resistance type signal generator. Please forgive my lingo I hardly know what I'm talking about lol.
I'm not sure what FP module if any I should be using to measure resistance.
07-06-2018 01:40 PM
Thanks for the reply.
Can you attach a screenshot of NI MAX of the issue you are coming across? I am not sure what timestamp you are referring to.
Brian J.
08-01-2018 02:59 PM
It's this one, but I think maybe it just wasn't updating because none of the values were changing.
But I'm going to start a new thread with a better proposed question, hopefully.
08-02-2018 09:37 AM
Hey,
I would verify if that was the case and keep us updated on the situation.
-Brian J.
