07-25-2007 07:19 PM
07-29-2007 10:00 PM
Hello Jack,
This is because the Ethernet Configuration VIs were written before the newest modules were released. However, they were designed so that if new modules were released, the user could select "Unspecified Module Type" and enter configuration parameters manually by entering actual IDs instead of selecting from the enum list given by "Input Range."
Clint M
07-30-2007 08:00 AM
08-17-2007 07:23 PM
08-18-2007 04:13 PM
08-20-2007 12:16 PM
09-02-2007 12:15 AM
Just curious...
Is there a way to programatically change the scaling values of cFP 2120?
09-05-2007 05:44 PM
Hello Jack,
There is not way to programatically change the scaling values of the channels for FieldPoint. You can only change the range, attributes, and deadband. If you want to change the scaling, you will need to just scale the values after they have been aquired in LabVIEW.
Clint M
09-05-2007 07:11 PM
09-06-2007 11:27 AM
